Files not found?
So, I'm completely new to Daz3D. I used the install manager to get everything done, and it looks all in order there. So, the first thing I did when I opened it up was create a figure. This is where it went downhill. The files tried loading, but went to a screen telling me some files couldn't be found. It then showed me a block figure instead of the Genesis figure I thought I'd see. I went and looked at the path the missing files needed to go, but I found they were already there.
At this point, I figured I somehow messed up the installation process. So I uninstalled the main file for Daz3D, and re-installed it. When I opened it, it did the same. At this point I became frustrated, and just uninstalled ALL the files, then re-installed them. Still this hasn't done the trick.
Again, I'm new at this, but I assumed it would have been a straightforward install, seeing as they have an install manager. Using the free Genesis and other models was one of the things I was looking forward to when using Daz3D, and everything is completely unusable.
Please help!
