self-lit material channel? (ambient?)
MistaraMistara Posts: 38,675
edited January 2015 in Carrara Discussion
ambient seems not the same as the poser ambient.
feeling totally lost.
how do i make a material light even with no lights in the scene?
what does the any shape light do?
how do i remove the multi channel from the shader after i accidentally start one?
thanks!!
Post edited by Mistara on
    can i make her hair self lit? or act as like a soft light?
    1053 x 800 - 656K
  • Steve KSteve K Posts: 3,470
    ... how do i make a material light even with no lights in the scene? ...
    thanks!!
    One technique I use a lot is to copy (right click - copy) the "Texture" map in the "Color" channel, into the "Glow" channel's "Texture Map" (right click - paste). (See attached screenshot). You can then adjust the amount of glow using the "Brightness" slider in the "Glow" channel.
    1336 x 718 - 174K
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,438
    anything glows, use same name as hair model
    edited January 2015
    I use one of two different methods:
    #1: Glow Channel
    Put a color multiplied by some high #(500 is my usual starting point and I'll go up from there depending on test renders)
    If you have Indirect Light turned on in the render settings this will both cause the object to glow and to give off light
    #2:
    Add an Anything Glows light to the object
    You have to parent the Anything Glows to the light (not sure if that's actually necessary, but I always do it)
    You have to enter the exact name of the object you want to give off light in the Item box on the properties of the Anything Glows
    This will make the object give off light, but NOT glow
    Setup of glow channel
    Setup of anything glows
    Test render - the ball on the left has Anything Glows and is casting red light, the ball on the right has a bright blue in the glow channel
    EDIT TO ADD: Steve K and Wendy Loves Cats said exactly this, but much more quickly, while I was making screenshots. ;)
    640 x 480 - 18K
    1685 x 1076 - 331K
    1269 x 835 - 125K
    Post edited by MarkIsSleepy on
    I should add that I think using the glow channel to cast light is more realistic looking, it is also a lot slower. If you want the glowing object to look like it is glowing with the Anything Glows you can put just a color or texture in the Glow channel of its shader and it will not cast light but will look like it is glowing.
    edited January 2015
    how do i make a material light even with no lights in the scene?!
    Answered above. :)
    what does the any shape light do?!
    If you mean the Anything Glows light - answered above. :)
    If you mean the Shape Light, it's just a regular light with three different options for how it is shaped (ring, ellipse, rectangle) - see attached renders.
    how do i remove the multi channel from the shader after i accidentally start one?!
    You can change the type of the shader through the drop-down on the "Top Shader" layer.
    640 x 480 - 11K
    640 x 480 - 12K
    640 x 480 - 11K
    screenshots allways mucho appreciated !!!!! :)
