RDNA Mushrooms -- need help
RDNA Mushrooms comes into the scene as a group of mushrooms. I cannot use the select tool to select and individual mushroom. I just bought the extension too but the shaders do not seem to work.
This https://www.daz3d.com/rdna-mushroomz ?
I have all those mushroom sets (the only way I will enjoy mushrooms, yech!).
RDNA Mushroomz Clusters and Rings 1, RDNA Mushroomz SmClusters and Rings 2, RDNA Mushrooms Vol 3 all load as monolithic props, and cannot be selected individually without breaking up the geometry. Lots of work.
Traveler's Naturals - Mushroom Singles Vol 1, Traveler's Naturals - Mushroom Singles Vol 2 each load individual mushrooms, as the names imply.
RDNA Mushroomz Texture Expansion 1, works directly on RDNA Mushroomz, but not on any of the other mushroom products described here. However, you can transfer the material settings between them all in the Surfaces Pane. Apply the texture to one of the RDNA Mushroomz, then select a surface, copy selected surface(s), go to one of the other mushrooms and select the same surface (cap, stem, gills/underside) and paste to selected surface(s) (the Mushroomz item has "underside", the others have "gills")
I still have no clue how the product works. All I can do is open up the group of mushrooms. I cannot figure out how to apply the mat presets even to the group of plants. Normally, a product has an actor or some preset you select and then can apply a material preset to it (like with hair). Usually with plants, you can select one specific plant and apply several material presets to it. I want to be able to create multiple instances of plant and place them where I want.
This product makes no sense to me and is useless as it is.
Well, you'll have to use another product, like RDNA Mushroomz with RDNA Mushroomz Texture Expansion 1. A texture preset is usually made for a specific product. The other mushroomz(s) do not have dedicated texture sets, so they are what they are.
i can not get them to show up when i click on a mushroom if i can not fix the problem i will ask my money back
