• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Cinema 4D Discussion
Plugin does not work in C4D R23
«12»
  • RezcaRezca Posts: 3,393
    December 2020
    autodolor said:
    Rezca, understand your position, coz I am an industrial designer, closer to Solidwoks files (license paid ..) Like you, we use Daz and his characters for hardly anything. Personally, I hardly use hands and to make some renderings with my designs, as their use, in reality. Maybe I use a hand position, or the whole figure. What I run away from is rendering with Iray, which is despicable. Arlnod or Octane are better engines, even Maxwell from NextLimit. With my little old laptop from over 10 years ago, it worked like a charm. With just 8Gb of RAM, an Nvidia Gt450M GPU, in an Asus N53s. I have plenty for what I do. Each person has their target..., but never wait for Daz to solve a problem, for many tickets  :D
    I mostly just want the critters,  and with how its currently handling some things I'm scared that the Dragon 3 will just implode in upon itself if I try using it anywhere outside of DAZ Studio, and I really really don't want to use D|S.  I stopped buying things from DAZ when they started pushing that DUFF format onto everything and the C4D Bridge was  what made me consider buying stuff from them again.
    Seeing it in action though, I'm back to reconsidering :/    I've been unable to get Pose Morphs from anything but the head,  many joints end up being aligned incorrectly,  weighting problems... It seems to produce the same results as Export FBX does,  just saving you the time of needing to re-assign materials and stuff. Handy I guess, but I was hoping for more (Like InterPoser Pro way back when. Siiiiigh.... I miss that plugin)
  • XanathonXanathon Posts: 88
    January 2021 edited January 2021
    A DAZ representative wrote to me in a support email (answered after over four weeks, yay! quality support! not!) that they have nothing to do with this bridge and if something does not work I should contact the plugin developer here in this forum to solve the problems.
    I have provided multiple problems here and elsewhere in this forum, but nevertheless, there was not a single update to the bridge and I have never seen a single post from the bridge developer.
    So basically if this does not work, you are screwed.
    I guess that DAZ paid the developer a little money to create the bridge but not enough to be interested to fix the many bugs and improve the bridge.
    A pity and another reason I am going to buy less and less from DAZ. Their support is just too abysmal.
    Post edited by Xanathon on January 2021
  • nonregla_7d6405cae7nonregla_7d6405cae7 Posts: 2
    Hey All,
    I took a look at the python code after going through the same issues. I fixed it...
    You need to manually copy the DazToC4D plugin to your R23 plugin folder
    If you want to do it yourself then use any editor and open the DazToC4D.pyp file that is located in the DazToC4D plugin folder.
    • Search and Replace all 'print' statements. They should all have parenthesis
      print('Hello, World!') not print 'Hello, World!'
    • Search for def next and replace with def __next__ (there should be 2 occurances)
    • Search for
      | c4d.DRAWFLAGS_NO_REDUCTION
      (with the ' |'  character) and delete them all (R23 got rid of this flag).
    That's it. If you don't know any code it's fine. Just search and replace those things and it'll work. I would share the file, but i'm not sure if that's allowed.
    Post edited by nonregla_7d6405cae7 on January 2021
  • jamslutjamslut Posts: 17
    January 2021
    nonregla_7d6405cae7 said:
    Hey All,
    • Search for def name and replace with def __name__ (there should be 2 occurances)
    • Search for
    Thanks for sharing this, however it didn't work for me. There actually weren't any occurances of def name in the file.
    January 2021
    Hey All,
    • Search for
    Sorry, my mistake.... def next to def __next__ it's in class TagIterator and class ObjectIterator. I have updated the original post.
  • alvarog_talvarog_t Posts: 0
    January 2021
    autodolor said:
    SOLVED. :D
    https://www.mediafire.com/file/huqzq1353ds50i3/daztoc4d.pyp/file
    Gracias amigo ya me funciono con la versión CINEMA 4D R23- la modificación en el archivo .pyp funciono!!!...
  • KI3KI3 Posts: 38
    February 2021
    autodolor said:
    SOLVED. :D
     Thank you so much for sharing this! I couldn't even get the plugin to appear post update without this!
  • chweintrchweintr Posts: 13
    May 2021
    Some of the code has been updated for R23 -  for instance, the DRAWFLAGS_NO_REDUCTION  has been removed and they tried to change floats for integers, but the script still does not run.
    I still can't get files to transfer.  OIn the C4D side it says 'nothing to import'. On the DAZ side when trying to run the script, the screen flashes but does not go through the prep process. Any thoughts?
    May 2021
    For me it still functions fine (But not perfectly) if I run it on  Poser files,  but anything using the new DAZ files it'll do what you're experiencing.
    Morphing Python  (Poser .cr2 file)   Export works fine!
    The Constrictor  (DAZ 'DUF' file)   <Nothing happens>
    I ran through and checked a dozen figures each.  Every Poser file exports fine - albeit with every joint's alignment being borked -  and every DUF file refuses to even initiate the script.    Honestly, I've taken to just exporting figures via FBX when possible and then tweaking them myself, but  I might look into the Blender one if the joint alignment problem's not present there though, since I hear most of the development effort in the Bridges is funneled into that one (Not hard to see why, Blender's free after all).
  • eddykatteddykatt Posts: 2
    March 2022
     That's cos the C4D Bridge script is pointing to an empty location.  Fix for Mac:
    1. Replace the .pyp in the C4D scripts folder with the one posted earlier in the thread
    2. Make a folder called 'temp3D' in Users/Shared
    3. Export an FBX from Daz to the temp3D folder titled "DazToC4D.fbx".
    It will import now with a nice IK rig but the face will be screwed up.  I guess you can just replace the head with the one from the fbx file you made.  idk, I'm gonna try going through blender.
    April 2022 edited April 2022
    I FIGURED OUT HOW TO GET THE C4D BRIDGE TO WORK IN R23!  It's messy but it works.  Basically you have to use the Blender Bridge to make a file for the C4D Bridge to open.
    3.  Export your character to Blender using the Blender Bridge
    4.  Find the .fbx file you just created here:  /Users/eddykatt/Documents/DAZ 3D/Bridges/Daz To Blender/Exports/FIG/FIG0/
    5.  Copy the .fbx file to here: /Users/Shared/temp3d
    6.  Rename the .fbx file DazToC4D.fbx
    7.  You can now import it to C4D using the C4D Bridge plugin.  Your character should come in fully rigged with eyelashes that follow the facial morphs.
    Post edited by eddykatt on April 2022
«12»
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
