Default HDRI loads in scene when I only want Sun-Sky
I want to render a bunch of scenes using Sun-Sky as the primary lighting, but I also have some spotlights. So I have my scenes set to render with "Dome and Scene" and I set "none" as the Environment Map.
The problem is that whenever I load up the scene, the default HDRI (DTHDR-Ruins) image is loaded into the Environment Map. I want these scenes to be set up to render using Render Queue, so this is preventing that from happening.
Anyone know how I can get a scene to load without the default HDRI?
  • FSMCDesignsFSMCDesigns Posts: 12,851
    There are only 4 settings in the environment tab. Sun-Sky setting will only work alone, unlike the dome setting which can be used with scene lights
  • Richard HaseltineRichard Haseltine Posts: 109,533
    Dome and Scene with no environment map gives Sub And Sky plus scene lights.
  • barbultbarbult Posts: 26,608
    edited April 2022
    Yes, but if you save the scene and reopen it, DS puts the default HDRI back in. I reported this as a bug many months ago (in DS 4.15).
    Request #375378
    Scenes saved with no HDRI image reopen with the default Ruins HDRI loaded
    April 30, 2021 23:31
    Post edited by barbult on
  • stefan.humsstefan.hums Posts: 135
    Not quite. Use the "Dome and Scene" environment mode, then delete the environment map (set it to "none") - and you get the Sun-Sky controls. And scene lights are still working.
    Practically a Sun-Sky-Scene environment mode. wink
    That only works until you save the scene and reopen it. Since version 4.15, DS puts the default HDRI back in when a saved scene is reopened. That makes it impossible to use this technique with queued renders. That is what the original question is asking about. I know no workaround for this problem.
  • HylasHylas Posts: 5,283
    Yes, this is a bug, and I'm annoyed that it's still not fixed. I use sun-sky + scene lights regularly so I run into this all the time.
    At least if you load such a scene and delete the "Ruins" default HDRI, it goes back to the exact sun-sky setting you saved before.
    That won't help you with queued renders, but at least you don't have to adjust your sun-sky settings anew.
  • OVDOVD Posts: 262
    So it is a bug. I figured that someone had a way around it, but not yet I guess. Thanks for clearing that up at least!
