Does GenX Still Work in DS4.20?
RCDescheneRCDeschene Posts: 2,816
edited April 2022 in The Commons
After a long hiatus away from Daz 3D, I've decided to get back into the swing of things and reninstall Studio on my desktop via the DazCentral. However, after installing Genesis Generations X2 (GenX2) with all the respective plug-ins, I'm noticing that the Source figures is greyed-out. I'm trying to get all my Genesis & Genesis 2 characters to Genesis 3 so I can XTransfer them to Genesis 8/8.1. Below is a screen of the issue:
Post edited by RCDeschene on
  • nemesis10nemesis10 Posts: 3,881
    It works for me...
  • NorthOf45NorthOf45 Posts: 5,733
    If the plugin loads, maybe it can't find the data. Make sure the AppData files are in the right place (%APPDATA%\DAZ 3D\Studio4\GenX2).
  • FauvistFauvist Posts: 2,289
    I had exactly the same problem with GenX with the LAST release of DAZ Studio and ended up having to use the Beta Public Build version of Studio.  There was no solution to the problem.  I tried everything.  That's why I'm not upgrading Studio any more. I cant afford to have features become obsolete. I am also never going ti stop using iRay because it would mean replacing ALL the textures and shaders for every surface of every product.  I did that once already when iRay made 3Delight obsolete.
  • RCDescheneRCDeschene Posts: 2,816
    nemesis10 said:
    It works for me...
    Are you using DS4.20 and DazCentral?
     They seem to be.
    1600 x 861 - 99K
  • jedijuddjedijudd Posts: 606
    I am running 4.20.02, and with Genx I do not have the problem of greyed out sources, the only thing I did have to do is locate V4 and M4 manualy to get them into the sources area. I just tried it and successfully transfered a morph from V4 to G3F
    Serial Number? Help -> About Installed Plugins sould show a green plug. If a number is required, there will be a field to enter one under the Registration column. I Started way back with version 1, and had to enter a serial number. I don't recall if I had to enter it again for version 2, but the nmber is still in my account.
