Missing files?
Hi.
This might be a question that should have been asked another place, but I haven't found one.
I have been using Daz off and on for a while, just the basics.
Yesterday I got messages about missing files for almost all figures! And when i looked in that folder,
the missing files is there. I have no idea what has happened, and I did re-install it twice with the same result.
On my laptop there's no problems at all.
I don't know where to look for help or how to find out what's wrong.
Is it my computer or has this happened to others as well?
Maybe this is not enough information, but it might be a known problem so I'll start here. ;-)
Regards
In Studio with the Content Library tab open click on the little box with sideways triangle and several lines (if you have Tool Tips turned ON in Preferences/Interface [and new users should] hovering over the box will show "click here to display options for the active pane"). Select Content Directory Manager, in manager expand DAZ Studio Formats and Poser Formats. The paths listed need to point to folder where your content is installed, that folder will have a "Runtime" folder and "data" folder. If you used DIM to install your content you can get the path from it. On the Ready to Install tab make sure Show Details is checked, if it is at the bottom of that tab there will be a window with "Content Path Shortcuts" and "Content Files Install To". Beside the "Content Path Shortcuts" is a button to switch to other library location if you have more than one defined in DIM, beside "Content Files Install To" is the path that DIM is currently set to install to. Simply add the DIM path(es) in Studio's Content Directory Manager.
Oh my god, I love you, thanks! :-)
For some reason, there were nothing in those folders, nothing at all.
Something must have happend, it never used to look like that.
Really weird but easy to fix as it seems.
I testet to figures now, no problems.
I really can't thank you enough, lots of love!
