Group items and duplicate as a single item?
ScavengerScavenger Posts: 2,674
edited December 2014 in New Users
The picture below is a stack of books.
It's made by a bunch of node instances stacked and posed.
Is there a way to select all of them and create a copy of the stack as a single item? (Or even copy them as a group of seperate items).
I tried making them a group, and duplicating that, but it just did a single book, not a stack).
EDIT: Looks like Duplicate Node Hierarchies gets me the "copy as a group of seperate items)
Post edited by Scavenger on
  • togstogs Posts: 11
    Parent each of the books to the one under it, select the first one, and Duplicate Node Hierarchy will then do the trick...
  • TotteTotte Posts: 14,779
    Put the all into a group, then duplicate if (if you want to be able to change the copy, or make instances.
  • NovicaNovica Posts: 23,925
    You can also save as a Scene Subset then they will load exactly where they were in the scene from which you saved.
