Bright Red spots on figure when rendered
Just installed DAZ 4.7( I have been using DAZ since 4.5).
Now, whever I use the Fiery Genesis lighting preset that comes with DAZ, I get multiple red spots on my figure. To be specific, it only appears to be happening on my Minotaur 6 HD figure, when using the fiery genesis light preset. Using other light presets I don't get any red spots at all. So far, I am only getting red dots when I am using Minotaur 6 HD while using fiery genesis lighting preset. I'm guessing this isn't a glitch or bug or some sort, and most likely something I need to fix in the render settings or something. Though I'm pretty much a novice when it comes to tweaking render settings. Does anyone know what might be causing the issue? Any help is greatly appreciated.
  • SzarkSzark Posts: 10,634
    Try changing the shadow mapping on the lights to Ray Traced instead.
  • edited December 1969
    That did the job, render looks perfect now. Thanks for the help!
    I am assuming the figure uses AOA SSS Shader base and will only work with raytraced shadows.
