Renaming and moving dials
More often than not, I have purchased characters for G8 which weren't cooked up in the cleanest of ways. I'll find a section in the Parameters tab, way down, and all the shaping dials crammed in there instea of finsing them in the Shaping tab under Actor/People. Also, the display names of both the group and dials are often just typed in full lower case. I eve have seen missplellings... is there a way to move and rename such things, assuming it wouldn't mess anything up?
  • Richard HaseltineRichard Haseltine Posts: 108,785
    Click the gear icon on the slider>Parameter Settings and edit the Path and Label (not the name). If you right-click in the Parameters pane and set it into Edit mode you can multi-select proerpties and edit their path in one go from the right-click menu. Note that the type has to be set to Modifier/Shape for them to show in the Shaping pane.
  • Thanks a lot Richard, I'll try that. Sorry about thye delayed reaction, some IRL issues kept me away :)
