Eyes washed out???
KuroFishKuroFish Posts: 39
I've been having issues with My V6 and V4 characters eyes washing out and looking kinda creepy?
Anybody else have this problem? Any fixes?
Thanks.
  • SzarkSzark Posts: 10,634
    Could be a few things.
    Too much Ambient
    Too much Specular
    Too much Light
    Hard to say really without more info.
  • srieschsriesch Posts: 4,243
    I have found a few eye materials that have had issues similar to that. Unfortunately I don't recall which ones or what the fix was, other than it was selecting one of the surfaces that makes up the eye and making a single parameter change. To see if this is what you are seeing, just quick try a few eye materials from several different products (if you have more) and if one of the other products works the way you expect, take a screenshot of all the parameters, then compare to your current eye's surface parameters and look for which parameters are different, then try duplicating the settings one at a time until the issue goes away.
  • KuroFishKuroFish Posts: 39
    Okay I think it was using the model “Stacia”, I’d been dabbling between her eyes and “Bree” for G6…
    I went back and replaced the figure with “Bree Eyes 03 Shadow.mc6” that seemed to do it. o_O
    Thanks for all your suggestions!! :cheese:
    If you want to learn this properly you shouldn't rely on presets but instead look at the surfaces and adjust. But if you are happy then carry on. :)
