Daz 4.7 without Micheal and Victoria?
Hi,
I am a modeler (3DS Max) and I'm learning to use Daz 4.7.
I'm Italian and my English is bad.
For this reason I used a picture that shows my problem. I tried to take a picture with all windows that relate to this problem.
I can not find anything of the things installed with the starter essensials.
I tried to uninstall and reinstall the packages but nothing has changed.
Which Version of Michael and Victoria where you expecting. If it is for Genesis 2 M and F base then they are sold separately.
For Real? I thought they were in the essentials.
So any version of Victoria must be purchased separately? Victoria and Micheal are Morph or figures?
What changes between different versions?
Sorry for the many questions :)
No you only get the BASE MESH Genesis and Genesis 2 which changed the way thing work.
http://www.daz3d.com/forums/discussion/24257/ this might help to answer all your questions. and no need to be sorry, ask away, that's what the forums are for.
Thanks, the link is very comprehensive.
Yeah Scott did a good job there and great resource.
Get rid of the last entry under DAZ Studio Formats, it creates a nested library within your first library entry. Genesis and Genesis 2 should not be appearing under Poser Formats in the Content Library tab unless you installed the PoserCF files which are not needed if you are only using Studio.
