Beta Stopped Working?
BratpiperBratpiper Posts: 47
Been using the Beta version full time, Just this morning I'm getting following message "Carrara has stopped working" on trying to start it up.
Worked fine yesterday - Suspect time limit kicked in as it's Jan 1st now?
Just checked the original build (243), and that's still working fine.
    Mine still works (other than the smart content, which I still can't get to appear)
  • EyosEyos Posts: 114
    I had this issue too after midnight. It seems that the cause is the LuxCore which expired.
    I downloaded the latest LuxCore from the thread below and everything is back to normal:
    http://www.daz3d.com/forums/discussion/50130/P105/
  • DADA_universeDADA_universe Posts: 336
    Okay, this is weird. I'm having exactly the same issue with my C8.5 (build 204) and it started today as well, the weird part is that I never installed the beta because I never saw much reason to. So does Carrara have some inbuilt self destruct timer or does it not?
    P.S: I already reinstalled Carrara twice (with anti virus deactivated) to no avail.
    See my post above yours.
    Wow, you're right, thanks, that solved it!
  • BratpiperBratpiper Posts: 47
    Thanks Eyos, that's cured it.
    I'd installed Luxcore not long after buying LUXUS so I was a bit wary of spending days redoing all textures a second time, especially as it's only Beta. After a quick look, I thought I'd wait for Luxcore to mature more, and basically then forgot about it.
