Some problems with install some products
With Home Erectus K4 I get this massage fout: 0x80004005
Sorry this one is in Dutch, hope someone know a answer
There are more products who do this
I install the products manually, I use Daz
its an unexplained error when copying
and I can see that the issue is that the pz2 has 0 bytes
so the file wont copy over weird that its happening on a manual install only normally happens on DIM installs when I create dummy files I had to put some dummy info in blank files.
all I can suggest is take note of which files wont install (I presume all 0 byte pz2 dummy pose files) and use a text editor to recreate a file of that name. And then place in the correct pose folder
or use a different extraction program to extract the files from the zip file if you are using WinRar download 7zip if you are on a Mac I am not sure of your different program options.
Thanks NeilV
I know now the problem it has somthing to do with a new ZIP file :-)
Windows built-in zip utility doesn't like zip files with 0k length files, use a free utility like 7-Zip. DIM doesn't seem to have a problem with them but it only works with zips from DAZ.
DIM can have a problem with 0 byte files this is why as a PA I am not allowed to supply them any more, and is why I add at at least one word of text to these dummy files now.
