Layer Daz renders in Gimp
I have been trying to create a crowd scene by layering rendered Daz studio 4.7.0.12 scenes in Gimp, but I am missing a key step.
After rendering I save as PNG then copy with the Snipping tool and save to my desktop. I bring them into Gimp using '' open as layer''.
I've tried the '' merge visible layers'' but all the happens is one layer disappears. I understand how layers work, but I not sure how to make multiple layers come together as one image.Should I be saving them in a different format?
Please share any knowledge you may have on this.
Thanks
The "copy with snipping tool" step is, I think, not needed. Once you've got the render saved as a png, then you've got it with the alpha channel needed to layer it in GIMP. Try saving the render directly to your desktop (or wherever you're sure of finding it easily) and open that as a new layer in GIMP. I'm not sure, but I think the copy stage you're using might be wiping out the transparent alpha channel. As far as I can tell (my experience is with Photoshop and PaintShopPro, not GIMP) you're doing everything else right — although "flatten" might be a better choice than "merge visible layers", if GIMP has that particular menu option.
Yeah the snipping tool is not needed, just drag and drop your PNG renders in to Gimp.
Please see image. Still not what I am looking for. Any thoughts on what's wrong now? They where standing next to each other, rendered one at a time.
That's after flattening the layers, right? Looks like you might have the layers in GIMP the wrong way round; what does the layer tool display look like before you flatten?
Yes, this is after flattening. This is with the layers reversed.
Just a guess, but do you have three layers (purple shirt, wall, green shirt) or two layers with the wall in both of them? There should only be one layer with the wall, and it must be at the bottom of the layer stack.
Finally!. I believe I got , now I hope I can keep it !
Thanks for your help SpottedKitty
A good start to your crowd scene. Don't worry too much about glitching a bit to begin with, this can be a tricky concept to wrap your head around once you get beyond the basics. I don't actually do much layering in postwork, so I have to keep rediscovering/reinventing various techniques myself.
