MEC4D New Lee6 outfits Just Released [commercial]
MEC4D
Hi Guys here are 2 new outfits for Lee6 , Traditional Chinese clothing from the Qing Dynasty and Shaolin Monk Uniform with 14 Kung Fu poses .
Here are updated 2 presets, to load all set at once, low and subd resolution
just overwrite your old files with this one ..
____________________________________
Files (61.3 KB total)
MEC4D_CHINESE_OUTFIT_G2M.zip
Link Available until
31 July, 2014
DOWNLOAD
http://www.daz3d.com/new-releases/mec4d-chinese-traditional-outfit-genesis-2-male-s
http://www.daz3d.com/new-releases/mec4d-shaolin-monk-uniform-for-genesis-2-male-s
Mec4D Shaolin Monk Uniform for Genesis 2 Male(s) (.DUF and .CR2)
14 King Fu POses
Kimono
FBMMichael6
FBMLee6
FBMGianni
FBMMichael4
Pants
FBMMichael6
FBMLee6
FBMGianni
FBMMichael4
Shoes
FBMMichael6
FBMLee6
FBMGianni
FBMMichael4
Spear
Spear Hair
Other Shapes supported in DAZ Studio by Auto-follow
1 Complete set of Uber Surface Custom Materials
Textures Include:
17 Texture, Diffuse, Specular and Normal Maps (4096 x 4096)
02 Reflection Maps (1024 x 512)
Texture Templates available through the Product Library
DAZ Studio Custom Uber Surface Material Presets (.DUF)
Poser Custom Material Presets (.MC6 and .DUF)
________________
Mec4D Chinese Traditional Outfit Genesis 2 Male(s): (.DUF and .CR2)
Gown
Shoes
Hair
Beard + 11 Styles
Hat
2 Load All Presets
1 Low
1 SubD
Custom Morphs to fit Michael 4, Michael 6, Gianni 6, Lee 6
Each Also comes in SubD
2 Material Options:
Low Resolution Option for Full Set
High Resolution Option for Full Set
Textures Include:
1 Texture Map (256 x 256)
3 Reflection Maps (1024 x 512)
10 Texture, Displacement, Transparency and Normal Maps (4096 x 4096)
3 Texture, Displacement and Normal Maps (5000 x 5000)
DAZ Studio Material Presets (.DUF)
Also in production but not yet released for Lee 6
Chinese Character base morphs and hair with Kung Fu uniform
The first two are mine! ;)
Thanks Simon for the support !! :)
did not released the last one due to the same outfit style was already released with the bundle .. however my products will include full character and realistic clothing but that for later .. maybe next month when I finish my Manchurian lady
The Wing Chun set looks awesome! Love the details!
Thanks mate !
Really great work, a must have!
I've bought the Chinese TRaditional outfit and hink it's a beautiful set.
Unfortunately, I have a bit of a fitting problem. I'm using Lee 6 and Maliaki.
Maliaki is giving me problem in the arm pit region, causing holes. It gets worse the more you raise his arms.
Lee 6, I have used "Stretching" from Every Day 'Poses for Lee 6, shows his elbows. I don't think the position is too extreme.
Is there a way to solve this (outside of hiding the elbow)?
Hi, does the person on the right side in your preview is Lee 6? it is is 100% Lee6 only then it is not how it should looks like , as it looks like there are no custom body morphs loaded at all.. Lee6 has JCMs for the arms bending and elbows plus own full body FBM
and I just tried and there are no issue with posing..
with other poke issues on shapes that are not custom made you can use smooth modifier and set it on generic .. it works best on the low resolution set
if you need more info how to set the smooth modifier let me know
waiting for your reply
A quick use of the Shaolin Monk ... http://fav.me/d7rxzon
I've found the problem
The dress and all work fine if I load them as "single item".
When I use the "!Loadall" .duf, I get the result shown. It seems that the JCMs don't load when you use Loadall, see attached Parameter tab.
From left to right image, Single load (OK), !Load All Subd, and !Load All Low Res.
Yes that is correct you are right , I tested on the single stuff and everything was fine . it is also possible that the LOAD ALL files was not updated when packed by DAZ
since my old zip is working fine and new zip from DAZ don't
thank you so much for posting this error , it saved me a lot of time to figuring what's going on
The dress and all work fine if I load the "single item".
When I use "!Loadall", I get the result shown. It seems that the JCMs don't load when you use Loadall, see attached Parameter tab.
cool render Simon thanks for sharing !!
P.S I will update the LOAD ALL preset files in a moment and share link so you guys can download ...
as it not working with other shapes too .. the custom morphs are not loaded with the preset unless you load it one by one to the scene
31 July, 2014
DOWNLOAD
Thanks, Cath! :)
Glad to be useful. :-)
Thank you for the repair file, and I'm looking forward for your new releases.
(PS: Is there a chance that you will do a traditional Korean noble outfit at one point?)
Yes on some point I will do.. I was talking about Korean noble outfits the other day .. as I spot some very nice one :)
Nice sets! you've been producing lately with a number of wonderful things for men. I'm so pleased. Excellent work! =-)
Thanks, I will have more for September :) really cool stuff including my new Buddy3 with a lot of clothing to choice from
I reserved August for the 3D ladies :)
Hi, when do you plan to release the Bruce Lee character and Kung Fu uniform ? I'm looking forward to it. :-)
I'm really looking forward to your morph and hair and new outfit. I did get the Shaolin Monk Uniform as I would have more use for that one. You do such exceptional work Cath!
Hugs
I did not released it early as there was similar style clothing on the main release .. so I guess will be ready for September together with the B.Lee morph
Thanks Richard.. I guess September will be the right time for that :) and thanks for the support as usual Richard
Hugs
The great products continue to flow. Looking forward to your full character & Wing Chun outfit set for Lee. :-)
I have a Genesis character that I want to use the Chinese Traditional Outfit Genesis 2 Male on but I can't get it to fit at all. Is there any chance you could update it to fit Genesis 1?
I am sorry ...I don't have Genesis 1 anymore I use only the last DS version, I would have to make new product for Genesis 1, new rigging, weight maps etc.. so not just update ...
tit is just not worthy the time
Ok, maybe I can use this http://www.daz3d.com/sickleyield/genesis-2-male-clone-for-genesis
Yes the basic will works with as well, however the robe will be not much poseable unless you adjust weight maps, however if you going to use standing poses only I see no problem
Yes I only plan standing poses. Thank you
I can't wait to see the Chinese character released. I am looking forward to this addition to your already great catalog of work.
