Simple Frames to Iray server queue adder
Hello, I want to write a script that goes through all the frames in a scene one by one, and adds them to an Iray server I already set up. The going through each frame part I already made, just not sure what to use to implement the "Add to queue"/"Job name" parts. Thank you.
Post edited by scyhoce on
This has been discussed before in this thread.
Because the forums are currently breaking pre / code blocks, I will repost the (undocumented, subject to change) functions here.
Added in 4.9.3.163
Thank you, any idea ho I could export/upload my scene current options like render time and tome mapping options with the frame file?
Unfortunately, I have not worked with this aspect of DS.
Tone Mapping options are stored in a DzNode now, and so should be automatically included.
Not sure about render time.
It's alright. Though I wanna say the tone mapping options aren't automatically included, I tested them myslef.
You can create those nodes if not included, and even better, create them with your preferred settings.
Do you know how? I can't find all the tone mapping options anywhere in the doc center. Also the I can't find the max render time settings.
