Simple Frames to Iray server queue adder
scyhocescyhoce Posts: 69
Hello, I want to write a script that goes through all the frames in a scene one by one, and adds them to an Iray server I already set up. The going through each frame part I already made, just not sure what to use to implement the "Add to queue"/"Job name" parts.  Thank you.
Post edited by scyhoce on
  • OmnifluxOmniflux Posts: 432
    edited March 2022
    This has been discussed before in this thread.
    Because the forums are currently breaking pre / code blocks, I will repost the (undocumented, subject to change) functions here.
    • DzIrayRenderer::exportRenderToBridgeQueue(QString)
    • DzIrayRenderer::exportRenderToBridgeQueue(QString,QString)
    • DzIrayRenderer::exportRenderToBridgeQueue(QString,QString,DzCamera*)
    • DzIrayRenderer::exportRenderToBridgeQueue(QString,QString,DzCamera*,const DzRenderOptions*)
    • DzIrayRenderer::exportRenderToBridgeQueue(QString,QString,DzCamera*,const DzRenderOptions*,int)
    Added in 4.9.3.163
    Post edited by Omniflux on
  • scyhocescyhoce Posts: 69
    Added in 4.9.3.163
    Thank you, any idea ho I could export/upload my scene current options like render time and tome mapping options with the frame file?
    Unfortunately, I have not worked with this aspect of DS.
    Tone Mapping options are stored in a DzNode now, and so should be automatically included.
    Not sure about render time.
    It's alright. Though I wanna say the tone mapping options aren't automatically included, I tested them myslef.
  • jag11jag11 Posts: 885
    You can create those nodes if not included, and even better, create them with your preferred settings.
    Do you know how? I can't find all the tone mapping options anywhere in the doc center. Also the I can't find the max render time settings.
