Issue: "Clothing Breast Fixes for Genesis 2 Female" won't install
Piquant
Perhaps this has already been flagged as an issue, but I searched for it and didn't find it anywhere. "Clothing Breast Fixes for Genesis 2 Female" will not install as a DIM only install. I did try to install it through Content DB Maintenance and got a listing in Content Library, but no product was installed anywhere. Any thoughts, or help, before I ask for a refund? Before anyone suggests it, I do not install anything through "Connect" anymore.
I have that one.
It installs a set of sliders you can use to adjust for clothing fits.
There are no user facing files.
Just sliders.
They get autoloaded on every G2F you load.
Select your character and then go to the parameters pane.
Click "All" at the top of the left column.
At the top of the right column type "PBM" in the search.
You should see a bunch of sliders.
Clear the search when you want to see the rest of the slider controls.
That's great. Thank you.
thank you!!
You're welcome
