Create a new surface on existing Clothing
All the old tutorials don't work as they once did in the new Studio, so how do you go about adding a surface to a piece of clothing?
I tried the old method of adding to a selected geometry in the editor, but the surface doesn't change the outfit.
  • Richard HaseltineRichard Haseltine Posts: 111,455
    They should work, nothing has changed that would be likely to break them.
    Goto the tools - geometry editor. The select the clothing and then highlight the polys you want affected. Right click and under geometry assignment, go to create surface from selected. Then type in a name and hit ok
    650 x 612 - 290K
