• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Maya Discussion
Daz to Maya Update 1.7
«12»
  • benniewoodellbenniewoodell Posts: 2,000
    February 2022
    tonnchristian said:
    Now, some months later - I have the same problem with daztomaya 1.8 and Maya 2022:3. The Plugin is not listed in the Maya Plugin Manager and i can't add it manually. This problem prevents me from my work. Does anyone have any solutions? The Github version also doesn't work for me.
    Couldn't you install Maya 2019 or whatever version you previously used, import it, save the scene and open in 2022? I had Maya 2022 but switched back to 2019 (I think.) I do the same with Blender if something doesn't work for 3.0, I set it up in 2.93, save it and open the file in 3.0 and it works. It's an extra step, I know, but it should work.
  • aescalle_654802c013aescalle_654802c013 Posts: 7
    March 2022 edited March 2022
    Hi,
    I get this issue on the option "Rig or Re-target Skeleton" - DazToMaya 1.8 with Maya 2020 or 2022 versions. When I click on the option, nothing change on the model. No new rig. The model stay in T position. But these new things appears in the Maya's Outliner (Wich doesn't comes as seen on the DAZ videos with the same hierachie):
    • Geometry
    • ExportSetup
    • hip_ctrl_zero
    And I get this error message:
    "// Error: file: C:/Users/MACPRO03/Documents/maya/modules/DazToMaya/scripts/DAZTools.mel line 1694: Could not add constraint or connections."
    The Basic Genesis 8 model stay in the T pose. I have tried to reinstall several time the DazToMaya plugin. Doesn't want to work even with the github files...
    Is someone to help or get same issue ? Thank you in advance for a help ;-)
    The complete log error is:
    1- For the import sequence:
    import maya.cmds as cmds
    import DazToMaya
    if int(cmds.about(v=True)) > 2020:
    import importlib
    importlib.reload(DazToMaya)
    else:
    reload(DazToMaya)
    DazToMaya.run()
    # pymel.core : Updating pymel with pre-loaded plugins: mayaHIK, invertShape, curveWarp, substanceworkflow, hairPhysicalShader, ATFPlugin, ikSpringSolver, retargeterNodes, RokokoMotionLibrary, sweep, AutodeskPacketFile, lookdevKit, Type, Boss, bifrostGraph, meshReorder, modelingToolkit, MayaMuscle, matrixNodes, bifmeshio, deformerEvaluator, shaderFXPlugin, objExport, bifrostshellnode, ufeSupport, GPUBuiltInDeformer, mayaVnnPlugin, substancemaya, svgFileTranslator, GamePipeline, tiffFloatReader, MASH, poseInterpolator, bifrostvisplugin, cacheEvaluator, mtoh, ik2Bsolver, xgenToolkit, AbcExport, gameFbxExporter, OpenEXRLoader, Unfold3D, mayaCharacterization, mtoa, rotateHelper, AbcImport, autoLoader, sceneAssembly, gpuCache, Substance, mayaUsdPlugin, OneClick, renderSetup, ArubaTessellator, substancelink, quatNodes, fbxmaya #
    Daz to Maya, run() method
    win32
    d2m start
    file -f -new;
    // Result: untitled //
    file -f -new;
    Importing Daz...
    // Logfile: "C:\Users\MACPRO03\Documents\maya\FBX\Logs\2020.1\maya2022imp.log" //
    setAttr -type "string" Genesis8Male.StudioNodeName "Genesis8Male";
    setAttr -type "string" Genesis8Male.StudioNodeLabel "Genesis 8 Male";
    setAttr -type "string" Genesis8Male.StudioPresentationType "Actor/Character";
    setAttr -type "string" Genesis8Male.StudioPresentationAutoFitBase "/Genesis 8/Male";
    setAttr -type "string" Genesis8Male.StudioPresentationPreferredBase "";
    setAttr -type "string" Genesis8Male.ControllerScales "Youth Morph=-0.445;CTRLGunnar=0;CTRLCaspian=0;CTRLHugren=0.0599999;CTRL-RSC-GarethHD=0.036;FBMRealBodiesJules=-0.0324572;Beast HD=0.17;CTRL-FIYousef=0.03;CTRL-E3DYonni=0.021;CTRL-E3DWalker=0.065;CTRL-E3DTamati=-0.014;CTRL-E3DSeb=-0.025;CTRL-E3DLeonard=0.03;CTRL-E3DLeon=0.02;CTRL-E3DKichiro=-0.0499999;CTRL-E3DGui=-0.025;CTRL-E3DGanaatarDemon=0.026;CTRL-E3DGanaatar=-0.026;CTRL-E3DDonovan=0.012;CTRL-E3DBjarke=0.032;Daniel=0.0650001;CTRLVladimir8=0.056;CTRLValentino8=-0.048;CTRLTheBrute8=0.17;CTRLScar8=0.056;CTRLMrWoo8=-0.105;CTRLMichael8=0.04;CTRLLee8=-0.06;CTRLLandon8=0.04;CTRLKjaer8=-0.02;CTRLJonathan8=0.04;CTRLHolt8=0.068;CTRLDiego8=-0.018;CTRLDasan8=-0.02;CTRLDain8=0.044;FBM_CGI_Miklos_Body=0.03;FBM_CGI_HKClaus_Body=0.02;CCRafael=-0.018;CCMagnus=0.1515;CCJack=-0.0172213;CCDragomir=0.0453";
    AutoIK...
    namespace fix finished
    // Error: line 1: No source attribute was specified. //
    // Error: line 1: The source attribute 'm5philliplashes.outColor' cannot be found. //
    // Error: line 1: setAttr: No object matches name: Genesis8Female.drawStyle //
    // Error: line 1: Non-deletable node 'perspShape' cannot be deleted. //
    // Error: line 1: Non-deletable node 'persp' cannot be deleted. //
    // Error: line 1: Non-deletable node 'topShape' cannot be deleted. //
    // Error: line 1: Non-deletable node 'top' cannot be deleted. //
    // Error: line 1: Non-deletable node 'frontShape' cannot be deleted. //
    // Error: line 1: Non-deletable node 'front' cannot be deleted. //
    // Error: line 1: Non-deletable node 'sideShape' cannot be deleted. //
    // Error: line 1: Non-deletable node 'side' cannot be deleted. //
    // Error: line 1: setAttr: No object matches name: Genesis3Male.drawStyle //
    // Error: line 1: setAttr: No object matches name: Genesis3Female.drawStyle //
    // New character 'Character1' was created.
    parentConstraint -mo -weight 1;
    // Result: lBigToe_parentConstraint1 //
    // Result: lSmallToe1_parentConstraint1 //
    // Result: lSmallToe2_parentConstraint1 //
    // Result: lSmallToe3_parentConstraint1 //
    // Result: lSmallToe4_parentConstraint1 //
    // Result: rBigToe_parentConstraint1 //
    // Result: rSmallToe1_parentConstraint1 //
    // Result: rSmallToe2_parentConstraint1 //
    // Result: rSmallToe3_parentConstraint1 //
    // Result: rSmallToe4_parentConstraint1 //
    // New Rig: Character1_ControlRig was created.
    // Error: line 1: setAttr: No object matches name: Scalp.cosinePower //
    // Error: line 1: setAttr: No object matches name: SummerLash_1006.alphaGain //
    DazToMaya Complete!
    2- For the Retarget Skeleton sequence :
    ---- Running DAZ Rigger v1.02 ----
    // Warning: file: C:/Users/MACPRO03/Documents/maya/modules/DazToMaya/scripts/DAZTools.mel line 491: New name contains invalid characters. Illegal characters were converted to "_". //
    ---- Geometries grouped ----
    // Error: file: C:/Users/MACPRO03/Documents/maya/modules/DazToMaya/scripts/DAZTools.mel line 1694: Connection not made: 'hip_scaleConstraint1.constraintScaleX' -> 'hip.scaleX'.  Destination attribute must be writable. //
    // Error: file: C:/Users/MACPRO03/Documents/maya/modules/DazToMaya/scripts/DAZTools.mel line 1694: Could not add constraint or connections. //
    Post edited by aescalle_654802c013 on March 2022
  • Richard HaseltineRichard Haseltine Posts: 108,475
    March 2022
    Please do not post images showing textured, nude figures. Use an untextured displacy mode, zoom in to show only the upper body (since its male), or give it some in-scene covering (not painted on afterwards).
    March 2022
    Sorry for this!
    April 2022
    aescalle_654802c013 said:
    Hi,
    • Geometry
    • ExportSetup
    • hip_ctrl_zero
    import DazToMaya
    import importlib
    else:
    reload(DazToMaya)
    DazToMaya.run()
    win32
    d2m start
    file -f -new;
    file -f -new;
    Importing Daz...
    AutoIK...
    DazToMaya Complete!
    If it's the same problem I had, go to where it says control rig in the top right hand side and change it to none. Then retarget the skeleton and it should work. Now here's the thing, I have yet to get it to work with a character with clothes or hair, so I just send them over with absolutely nothing, get the rig set up and animate that and send the keys back into Daz to apply to the character and render in Daz. If you happen to figure out how to get the skeleton to work with the character having clothes, please post it here as I'd love to know how to do it. I'm sure it's doable but I don't know Maya well enough to know what's what.
  • EichtamEichtam Posts: 9
    April 2022
    Hi,
    I started having issues with Daz to Maya plugin today. It was working fine a few days ago but there was a problem when I opened an existing project in Maya 2022. The control rig was where I last saved it but the G8F mesh was on its back. The pivot point was the same for both the rig and the mesh. When I moved the hip control, the mesh would react as it should but it was rotated -90°. It was very strange so I reinstalled the Daz to Maya plugin and even uninstalled and reinstalled Maya. It only got worse because now I can't get the plugin to work at all. I did the whole Github process to get it working in the first place but I can't get it to work again.
    Like many on this and other threads about the issue,  I'm getting the following error:
    // Warning: file: J:/Applications/Maya2022/scripts/others/pluginWin.mel line 316: Failed to call script initialize function //
    // Error: file: J:/Applications/Maya2022/scripts/others/pluginWin.mel line 316:  (DazToMaya) //
    I'd greatly appreciate any advice on how to get this working again without having to go back to Maya 2019.
    Thanks in advance!
    Specs:
    Windows 10 Pro
    Maya 2022
    Daz 4.15
  • blainemillerblainemiller Posts: 59
    December 2022
    updates with no directions. youtube directions, github this, yadda yadda that... blah blah blah.  Yes the software is free so I should shut up. But the content isn't.... so how about a working update through the installer?
  • dustinmeyer1234dustinmeyer1234 Posts: 134
    February 2023
    so I can no longer generate face controls is this known? I follow the video from two years ago just saying bruh hit the button but I get errors now and nothing seems to work to get facial bones? even projects I saved before that had facial bones seems to have reverted to nothing super cool stuff its like this this is still in early beta. is there a discord this this app or are we just having to sit here on the fourms waiting
  • gpool55555gpool55555 Posts: 0
    November 2024
    How to export poses?
    I was able to export characters without a problem.
    But I want to export poses. And I can't find the way to do it.
    Please help?
«12»
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
