Is this error a bug?
I was told that my system has changed too much and I have to prove that it is me that is using DazStudio. The only thing that changed was I added 1 new drive for file backups. The boot drive that Daz studio is installed on is still plugged into the exact same SATA port. it is possible that some of the other drives are now plugged into different SATA ports on the same motherboard.
I believe I have moved SATA ports before without problems, but I am not 100% sure. I do know that I have added and removed hard drives without problems.
I am not super worried. I am just asking if this is a bug or the actual intended consequence of simply using a different SATA port.
(I am running the beta version)
  • Richard HaseltineRichard Haseltine Posts: 109,282
    It shouldn't matter, unless you have very old Connect-only encrypted content - it's saying that it needs to revalidate your account, but if your content is - as it should be - unencrypted it is just a harmless reminder (though I am surprised it still pops up, I don't recall gettign it before I logged in when I installed on the clean system a couple of years ago).
    Thanks Richard. Yes, I assume it is harmless and I assume that if I log in to my account it will go away. My question though was it intentional to trigger a verification for simply changing the SATA port the hard drive connected to. To me, that seems silly. LoL. I forgot I did unplug my case fan. That must have been the trigger. I have one less can fan therefore must be a new system.smiley
    I would post a bug report if I knew if this is a bug, but really as long as it goes away when I log in next then it isn't a real problem for me.
    I don't know what triggers it, and of coruse since it is (or was) meant to be a verification system Daz hasn't given any details.
