Reality - Object does not render properly
n.jmurovn.jmurov Posts: 91
I'm having problems rendering the below object that I imported from Blender. There is supposed to be one material surface and I apply Metal - Gold shader but parts remain black. It renders properly in 3Delight. Thanks.
  • Richard HaseltineRichard Haseltine Posts: 109,619
    That looks like an issue with the normals. Try selecting the polygons in DS using the Geometry Edit tool and then right-click and select Geometry Editing>Flip Normals of Selected Polygons.
  • HergtHergt Posts: 1
    I have had the problem of objects failing to render and disappear. If for example, I have 4 figures the hair for 2 will be missing in the render. If I go back and rescan the scene the 2 that were missing may appear and the other 2 will not appear. Confused how this happens.
