SY Invisible for Genesis 8
DPWDPW Posts: 267
Hi,
Just purchased SY Invisible for Gen 8 that isn't working. No matter what I do, it just simply isn't working. Not sure if it's my settings, but any help would be much appreciated.
Thanks,
Dean
  • AlmightyQUESTAlmightyQUEST Posts: 2,006
    In what way is it not working (error message, doesn't change anything when you load a preset, preset loads but doesn't appear in render...)? And what version of Studio are you on? I don't know if any of the changes that affected "ghost lights" in the latest version of Studio might be affecting some of the effects from this set.
    Nope, it doesn't use anything like that.
    I also need to know what the error the user is having is, though!
    Normally you would load the suit onto the figure, select the figure, choose "hide Genesis 8" preset, select the suit, apply a shader to the suit, and then apply a transmap to the suit.
    Which step of this is not working?
  • lstarnlstarn Posts: 3
    If I follow the procedure, it works until I get to applying the shader. No matter which one I choose, it does not change the suit. Thoughts?
  • barbultbarbult Posts: 27,524
    To apply a shader, you need to select the object in the Scene pane AND one or more surfaces in the Surfaces pane.
    Thank you, barbult.
