A valid PostgreSQL CMS connection and Access is Denied
2»
  • Yeah, not in the same folder but all under the same main folder in the drive F:
    The situation is now that as soon as I change the content paths from DIM back to F, DS won't start again. But when I change the paths back to C: then it starts, without me installing or uninstalling anything. So apparently changing the installation paths in DIM also changes the files that have some database info.
    Apparently then, if I want to keep installing content to my F: drive, I either have to first install it in C: and then move it from there to F: or always temporarily change the paths in DIM and then back.
    Or maybe there is a midway that I just change some of the paths to F and keep some pointing to C...??
    Again, this is the kind of problem that didn't exist with the previous DAZ versions. I did have many problems finding my content but at least DS always launched.  It would be great if whatever was changed in this respect, is returned back to the way it was :)
  • Richard HaseltineRichard Haseltine Posts: 108,920
    Content paths or the Content Cluster? They are different - the latter is the database folder.
