fitting issue with object transfer utility *FIXED*
thell_michaelthell_michael Posts: 29
HI
sorry for the maybe noob question but i have an issue with fitting an outfit to my genesis 8.1
i created a shirt in Marvelous Designer based on exactly the avatar i m using on DAZ (exported it to make sure size fits)
then I import the shirt at fbx and it fits perfectly (as i d expect)
then I use the object transfer utility to fit it to the avatar  (see screenshot)
BUT as soon as i do that the shirt shrinks a bit and parts are inside the body of the avatar
i watched a couple of videos on the topic but none had that issue :(
Post edited by thell_michael on
  • felisfelis Posts: 6,103
    I would say, for source (G8F) set shape to current, and set a checkmark in reverse source shape from target.
    yes
    thanks, that works
