Putting Daz 3D on my main drive and Daz content on another...
in The Commons
Can anyone direct me to a tutorial on how to setup Daz Studio on my main drive and then connect it to a secondary larger drive to store 3D content. Hope I made that clear
Otherwise, I would quickly fillup the main drive with 3D assests. Also, is an external drive a feasble option.
Thanks,
Kent
DAZ Studio Edit -> Preferences -> Content -> Content Directory Manager -> Content Sets -> Current Directories -> (Poser/DAZ Studio Formats)
Change/Add your content directories there manually.
If you're using DIM, go to DIM's Settings ->Advance Setting -> Installation
Change the recommended folder with the one you're using with DAZ Studio.
It works perfectly doing that.
I'll give it a try...thanks!
If you want to do this use Install Manager rather than Daz Central https://www.daz3d.com/get_install_manager/
Thank you Richard...I ordered a new computer from B&H Photo and soon as I get it (back ordered) Daz will be my first program install. If I have any problems, will let you know.
Kent
I've attempted to use the above instructions to share my multiple Poser runtimes with Daz3D. The install manager makes it look like I've got them, but I can't find them in the actual DAZ Studio 4.2 application at all, either under Smart Content or under Content Library. How do I find my assets?
