problem with the texture models
torrentos121torrentos121 Posts: 1
Download Models. The whole problem can be seen in the attached picture. Is it possible to somehow improve texture butt heads with the body?
  • Richard HaseltineRichard Haseltine Posts: 108,695
    Do you have the Michael 6 base? The character you are loading wants the Michael 6 UV set and morphs, which aren't being found.
  • scorpioscorpio Posts: 8,533
    Looks as if something isn't installed correctly, the problem with the textures is its using the wrong UV, DS is looking for the M6 UV which should have been installed when you install Michael 6.
    Michael 6 HD is only an add on for the base Michael 6
    http://www.daz3d.com/michael-6
    this is what you need.
    Daz have a 30 days return policy so you can if you want return the HD set and get just the base.
  • torrentos121torrentos121 Posts: 1
    Ok. The decision is clear. Thank U.
