CPU or GPU in rendering?
ShimamuraShimamura Posts: 70
edited March 2022 in The Commons
Hi, my pc have a 11th Gen Intel(R) Core(TM) i5-11300H @ 3.10GHz   3.11 GHz, and a Windows  11 OS. Ma Graphic Card ia a Nvidia GeForce RTX  ti.
In render setting, by default, in advanced, i see that both CPU and GPU is selected. This is my new pc, and in the old pc i saw only the GPU selectable.
What i have to to: use only Nvidia, or both for iray rendering? I read on Rendeguide that both could be not always the good solution.
Thank you for your patience.
Post edited by Shimamura on
  • I use both, with no problem.  What kind of Nvidia GeForce RTX ti do you have - 3060, 3070, 3080, or 3090?
  • Richard HaseltineRichard Haseltine Posts: 111,482
    Try doing a few test renders with and without the CPU contributing, see how the times compare.
  • Matt_BrownMatt_Brown Posts: 177
    I found that GPU only works best on my rig. However, I do have CPU fallback enabled for when I max out the vRAM.
  • benniewoodellbenniewoodell Posts: 2,001
    I always have CPU turned off. When I leave it on, it seems like my renders are slower, and sometimes it falls to CPU from my GPU even though it shouldn't be doing that. When I click CPU off, those files render fully on the GPU. Not sure why that is, but that's been my experience so I never have it checked.
  • ShimamuraShimamura Posts: 70
    Thank you for your response. I have a nvidia 3050. I tried with both, but it seems slower than the render i did with GPU only.
    I read about that situation about 6 months ago & your outcome is correct. The CPU is so slow that the GPU will finish before the CPU and your renders will take longer than GPU only.
  • rrwardrrward Posts: 556
    I just put a 16-Core Skylake monster in my render rig (for non-DS reasons) and did some testing. Even that monster slows down GPU/CPU mixed renders.
    It doesn't seem to make much difference on my system - RTX 3070ti / Ryzen 5800x.  Maybe it is the complexity of the scenes that I render,  Mine are fairly simple, but I do use dForce Hair, both strand-based and "cloth".
