Transfer rigging
I was going to model a tight skirt (currently just a quick test).
I therefor posed G8F with thigh bends side-side -6 degrees, and modelled the skirt around that.
When doing transfer rigging I used same pose and the attached transfer utility data.
But no matter how I try the middle row of vertices gets affected (see pictures).
Anybody who can advise how to avoid that?
  • Richard HaseltineRichard Haseltine Posts: 108,617
    You need to bake the rotations - Joint Editor right-click menu>Edit>Bake Joint Rotations. Then when the skirt is rigged you apply the opposite bends to it and bake those rotations. There is, as I recall, a Youtube video from Daz covering this in repsect to high heels but the technique would be the same here.
  • felisfelis Posts: 5,946
    Thank you.
    I remember having seen that video, but as I never (at least untill now) have made shoes with heels, I had forgot about that.
  • I use a smoothing modifier  to even out the centre parts...
