After this blonde hair with the same hair colouring style at the bottom
So for G8F/G3F I am trying to get the hair and more importantly the colouring style in the picture for the blonde hair with the red streaks along the bottom. Is this something you have to buy pre-done on hair or is there some sort of hair colouring suite that allows you to do this? basically I am considering trying to use something like this: https://www.daz3d.com/friday-hair-for-genesis-3-female-s
Although that one in particular comes with different hair colours it doesn't have them as partials. Any advice here? thxxxxx.
  • felisfelis Posts: 5,899
    edited March 2022
    OOT often has an add-on product to his hair products, which usually include mix of colours.
    If he has a product similar to this I don't know.
    Example: https://www.daz3d.com/2022-01-hair-texture-expansion
    Post edited by felis on
  • DrekkanDrekkan Posts: 460
    I'll keep looking thx.
  • Consider making use of the templates and make one with the desired shades of colour?
  • MimicMollyMimicMolly Posts: 2,322
    edited March 2022
    Have you considered editing or painting your own hair texture? A lot of hairs use a vertical tiling pattern, so you could paint your own and then swap in the Surfaces section. (In Iray, this would be in the part that says "Base Color.") Here is an example of a painted hair tile I just did on my phone. (Only used the round default brush, no resources.)
    1000 x 1000 - 437K
    Post edited by MimicMolly on
