iRadiance - HDR Mesh Lights Volume 2 for Iray
2»
  • UthgardUthgard Posts: 878
    barbult said:
    Uthgard said:
    I think what they are saying is that they will use LDR for opacity and HDR for luminance (thus the increased memory consumption).
    Thank you for the explanation.
    Considering how much trouble your posts have saved me and how often you have? Don't even mention it, consider it an infinitesimal part of your good karma passing by.
  • GeffeGeffe Posts: 63
    DimensionTheory said:
    Geffe said:
    Since the 4.20 update the lights in this product are crazy bright. It seems to be something to do with the image in the luminance setting. Both of the pics attached are done with the environment set to scene only lighting, so the mesh light is the only light source. Even with the luminance turned right down to 1 (second pic) the light is still very bright.
    There is currently a product update going through QA that will fix this issue.  Iray had a recent change that modified the qay HDR textures work in opacity, so brightness values were getting multiplied by like 1000x.
    The update just uses LDR JPG textures for opacity (slightly more memory consumption due to two textures being used per light).  If you want to use the lights now you can convert the HDR maps to 8-bit and plug them into opacity, otherwise the update should be coming soon.
    Cool, thanks for the update (both the info about the update, and the actual update).
  • barbultbarbult Posts: 26,323
    edited March 2022
    I got the update from DIM today. It is working well. You are the first to update any product that I own to address the 4.20 Iray changes. Thanks for your speedy response!
    I used an environment HDRI and two Light L lights in this portrait - one in foreground and one as backlight.
    2000 x 2600 - 3M
    Post edited by barbult on
    edited March 2022
    @DimensionTheory It looks like this product is not completely fixed. The "DTML! - Turn Mesh Light Invisible" shader preset now essentially turns off the light, because just settings opacity to a tiny number no longer creates a "ghost light" the way it used to.
    Hmmm... no response. I'll submit a help request.
  • DaventakiDaventaki Posts: 1,624
    I'll turn in one also.
  • ZoZo Posts: 399
    Hi guys,
    I bought this product from outlet store today, but it does'nt appear in product list ( either Smart content or Content librairy, i see the lite version but the full version is not found, i try to uninstal re install, removed lite version but no chance, any idea ?
    * I use 4.24.0.3 premier version
    Thanks
  • Write IdeaWrite Idea Posts: 451
    Zo said:
    Hi guys,
    Thanks
    I can confirm the same.
    It does work if you install in manually, however, not in smart content.
  • Richard HaseltineRichard Haseltine Posts: 108,523
    Write Idea said:
    Zo said:
    Hi guys,
    Thanks
    Smart Content is not an installation method, if you mean Daz Connect (installing through Daz Studio rather than Install Manager or manually) then many scripts are not written in a way that can cope with the different file locations and the way the location is reported when installed through DS.
    Richard Haseltine said:
    Write Idea said:
    Zo said:
    Hi guys,
    Thanks
    When I install something manually, say something I purchased off Renderosity, it will appear in the Content Library, not in Smart Content. That is what I was referring to.
    Write Idea said:
    Zo said:
    Hi guys,
    Thanks
    Content from other sites may well lack metadata, and if not it will have to be imported rather than being  added during isntallation (exept for a few products that have Install Manager compatible zips). This will not be related to things working or not, however.
