Hey new to daz3d need some help please.
What I need to do is cut a character V4 completely in half length or breath so we can see inside he is this possible if so how?
Thanks Jonny
Thanks Jonny
The Anatomy Starter Bundle ought to give you the raw materials, as it were. Exactly how you'd "cut" them, though, I couldn't say.
You can do it using transparency map but you will have to paint the inside in postwork as there is nothing inside.
To make the transparency map you just repaint the skin map (the one on the difuse value on the surface panel I think)) use black for the part you want transparent and white for the visible parts. You only have to do it on part of the body who will have some transparency no idea which has you didnt mention the sens you want to cut it. For the body part you want entirly removed you just have to use the opacity value, no need of a transparancy map ( exemple if you cut her in too verticaly you dont need a map for the missing leg, foot, arm and hand, but you will need one for the torso neck head etc)
Ok cool gives me something to mess around with thank you for your time gents.
Like "Androol" said
OOH SO HANDY THANKS!!
