Dreamlight Render Sphere Surface Tab problem
Wakakanada
I just installed Dreamlight's Render Sphere. It appears to load correctly, but when I try to access the surfaces tab, Daz Studio does not acknowledge the object selected. The other tabs [parameters, shaping, and posing] all recognize the selected object, but the surfaces tab remains greyed out reading "No Selection".
Has anyone else encountered this, or have any insight or solution?
I don't have the product, but from what I've seen of it in the video on the product page, you need to keep expanding the sphere in the scene tab until you get to the actual objects.
I re-watched the video and it is clear the product is not functioning properly with Daz Studio when it comes to surfaces. I will reinstall it to a different location and see if that helps, although given the present install works exactly as expected other than the surfaces tab, I have my doubts. If things were in the wrong place, I would expect no texture to be found upon loading the product.
I reinstalled to a second location and the same results, other tabs recognize the selected item, but the surfaces tab states "No Selection".
Okay, not sure why, but I closed DS and rebooted my iMac and the surfaces tab now works...strange...but okay.
