TexAnim 2022 0414 - Animate texture maps and .VDB Volumetrics
mCasualmCasual Posts: 4,607
edited May 2022 in Freebies
Ze Link : https://sites.google.com/site/mcasualsdazscripts/texanimfords3
texanim exists since ... a long time ago and the last update apparently was in may 2012, ah the springtime, bring it on
What's New in TexAnim 2022
 texAnim 2022 retains all of texanim 3.02,'s functionnality
texAnim  2022  includes a timer that inserts a delay between changing textures and rendering the scene,
this is needed mostly for OpenGL and Filament renderers which need time to display scene changes in the 3D Viewport
texanim now works for old shaders that have non-standard maps like the "Normal Map"  on the DSDefault shader
texanim 2022 Now displays your loaded "job file"
notice in the job shown in the image below that i left the "prefix" entry blank, not a blank space
i typed Prefix[Tab][Enter]
So for a good TexAnim Experience ( ha ) you have to type your job file without invisible blank space
so you type it like : Prefix[TAB]theprefixofmymapfiles[ENTER]
where theprefixofmymapfiles is the prefix of your map files
my 2010 video presenting texAnim in action, 2010 do we even remember 2010
NEW ! Tutorial
Rendering Animated VDBs in Daz Studio
https://sites.google.com/site/mcasualsdazscripts5/TexanimVolumetricsTutorial
Post edited by mCasual on
  • atoxicatoxic Posts: 155
    thanks again
  • SWTriumSWTrium Posts: 24
    Thank you!
  • Many thanks.One question if I may! Is it possible to create a crowd scene for a background? Say a circus crowd with a slight animation maybe head and arm movement and put it on a billboard or a plane with a texture with an alpha channel and insert it in the background? Cheers
  • mCasualmCasual Posts: 4,607
    edited March 2022
    there's free and non-free low-poly little-people-with-background-stories floating on the net, and planes and animating a moving plane and ribbon with d-Force i guess or doing the banderolle animation in blender and importing it as a morphable animatable prop using https://sites.google.com/site/mcasualsdazscripts2/mcjobjstomorphingprop  . actually this cloth sim was imported from poser's clothsim
    into Daz and rendered there
  • With a few tweaks, this can be used to animate VDBs.
    I had to change
    img = imgr.getImage(inPic );
    to
    img = inPic;
    and
           if( oProperty.className() == "DzImageProperty")
    to
           if( oProperty.className() == "DzImageProperty" || oProperty.className() == "DzFileProperty")
  • RobotHeadArt said:
    With a few tweaks, this can be used to animate VDBs...
    Awesome - thanks!
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,260
    thanks, will try when I have time
    yes
    i'll check this, the recent change to that section of the code was to accomodate the DSDefault normal map
    now i see that there's also properties that are  DzFileProperty
    I had to change
    to
    img = inPic;
    and
    to
    edited April 2022
    animated vdbs will be added today ( sorry 'bout the long wait )
    and the shoe-straps wont poke-in
    thanks go to RobotHeadArt
    655 x 1080 - 384K
    edited April 2022
    the mod i made looks like this
    • if( oProperty.className() == "DzImageProperty" )
    • oProperty.setValue( img );
    • else if ( oProperty.className() == "DzFileProperty" )
    • oProperty.setValue( inPic );
    • else
    • oProperty.setMap( inPic );
    the handling of image properties was added in 2022 for  materials that have the Notmal Map property as a DzImageProperty
    in the case of Volume shaders the .vdb property is a DzFileProperty
    the other textured channels like DzColorProperty are handled by the second 'else'
    and here's the "job file" for my animation  test
    Object Sphere
    Surface Volume
    Property Volume File
    Path C:\Users\jacqu\Downloads\Fire_01
    Prefix embergen_fire_a_
    Padd 0
    Suffix vdb
    LoopStart 0
    LoopEnd 100
    First 0
    note: i renamed the primitive-sphere Default material to Volume as suggested by this video-tut
    the .vdbs were in C:\Users\jacqu\Downloads\Fire_01
    they were named embergen_fire_a_0.vdb, embergen_fire_a_1.vdb ... embergen_fire_a_100.vdb
    notice that the filenames dont use zero-padding, so the zero-padding is 0
    if the files were named like embergen_fire_a_000.jpg ... embergen_fire_a_100.jpg
    then the zero-padding would be 3
    for an unknown reason, Daz Studio's Volumetric plugin protested about embergen_fire_a_0.jpg
    but frame 0 rendered ok i think
    when the new texanim version is online i'll post again here and show you the test animation on YouTube
    655 x 1080 - 192K
    edited April 2022
    here's the demo
    https://youtube.com/shorts/tFXjzSx2pk8
    i'll also add a WebHelp button that opens your browser in texanim 3.02/texanim2022's release page on my very safe google sites site
    748 x 554 - 172K
    edited April 2022
    TexAnim 2022 with Animated VDB support
    it is ready !!!!!
    532 x 532 - 218K
  • FirePro9FirePro9 Posts: 456
    Here are some pretty cool free animated VDB files to play with:
    https://jangafx.com/software/embergen/download/free-vdb-animations/
     thanks that will give me the occasion to test if texanim and Daz Studio can play nice with those VDBs
    edited May 2022
    ( duplicate removed )
    but since we're here
    uh
    old smoke effects using my free mcjJet2
  • I have downloaded the free VDB effects. Are there any instructions on how to use these in DAZ Studio? Are they used on a primitive and with Texture Animator 2022? Cheers
     on the texanim release page and/or the demo video i put a link to the introductory video i watched before upgrading texanim
    the other documentation you get is on texanim's release page and this forum thread
    i'm about to test my only second vdb animation
    the video tutorials can be found by youtube-searching for [ vdb daz3d daz and volumetrics ]
    and there must be some threads about vdbs in the neighboring forums
    maybe i'll make a text+photos tutorial from my 2nd test
  • Many thanks for your replies.Cheers
    edited May 2022
    Tutorial Rendering Animated VDB Volumetrics in Daz Studio Using Texanim
    the result of the tutorial 2 tornados 128 frames
  • Any way we can download this tutorial? Cheers
    you click-right in your browser and save it as html, then it saves it as html including the images, and you can open that .html file while offline
    or you can install a pdf extension or "software printer" and print anything as a pdf
    edited May 2022
    @csteell_c2893e4ab6
    or you can install a pdf extension or "software printer" and print it as a pdf
    the chrome browser can also save the page as 1 .mhtml file which incorporates the images
    here it should open in any browser https://drive.google.com/file/d/1yTjKCBRM3o8N3Sp3Z2LvYULaC1Ch_Y2y/view?usp=sharing
    edited May 2022
    A 250 Frames Volumetric Animation made with TexAnim2022's Help
    Video! Gabrielle's Hot Pink Morning Daz Volumanim
    here is the Job File ( paths on my PC but you get the idea )
    Object Sphere
    Surface Volume
    Path C:\Users\jacqu\Downloads\FirePlumeVDB\fire_plume\fire_plume_VDB
    Prefix firePlume_
    Padd 4
    Suffix vdb
    LoopStart 0
    LoopEnd 249
    First 0
  • TugpsxTugpsx Posts: 806
    Cool, lots of potential.
    i still have to see how blander uses the "fire/temperature" data and adds the emissivity in the clouds, the "density"
    data in the vdb is all that i saw Daz Studio do so far, and they add luminous objects in the clouds to get the look
    someone in a video said it's a matter of editing the volume shader in shader-mixer or shader builder
    that's a non-volumetric gif
