Having trouble with the morph for the third eye from Arm of the Demon King
ShortlegDoggoShortlegDoggo Posts: 125
https://www.daz3d.com/arm-of-the-demon-king-for-genesis-81-males
I'm trying to use the third eye here, but when I apply the morph to my 8.1 figure so there's a socket for it, it's just a shallow pit and not the correct shape. Subdivision is cranked all the way up, so it's not that. Kind of odd.
I've attached a picture of what my render looks like (on the left) VS what I'm trying to accomplish (on the right).
I'm not new to Daz at all, but there's definitely a chance I'm missing something obvious as I'm a bit sleep-deprived right now. cheeky
Post edited by ShortlegDoggo on
  • Are you sure that the render divisions are turned up correctly, assuming that is a render? The outline of the socket also looks very segmented.
  • ShortlegDoggoShortlegDoggo Posts: 125
    edited March 2022
    Thanks for replying. Yeah, they were maxed out. SubDivision level 4, Render SubD Level (Minimum) was at 10. Neither would go any higher.
    I restarted the whole scene from scratch and now it works fine. So the problem must've been between the keyboard and the seat. wink
  • FenixPhoenixFenixPhoenix Posts: 3,184
    There's two settings for subdivision. Viewport SubD and Render SubD. In your render, it looks like you have the subdivision set to 2. So if you're rendering out the image, you want to ensure the render subdivision is 3 or 4. If you're doing an iray preview, I'm not sure if it takes into account the viewport subdivision or render subdivision, though.
  • Richard HaseltineRichard Haseltine Posts: 108,538
    Also you need to make sure that the Mesh Resolution button iss et to High nor Base - I suspect this was the issue.
