Daz Studio Closes after loading a character
DippyDippy Posts: 4
edited December 2014 in New Users
Hi All,
The last couple days DAZ closes after loading a character and I move the mouse over the display area?
Uninstalled reinstalled installed 4.7 still happens, any ideas?
Regards,
Keith.
(mod edit: revised title so people could know what was the subject )
Post edited by Cris Palomino on
  • Cris PalominoCris Palomino Posts: 12,634
    Which character are you loading?
  • DippyDippy Posts: 4
    Hi Cris,
    Thought about that as well, tried several of different detail levels, Daz still closes. I have just added an Isku keyboard, have a feeling it's resources, I'm using a laptop with only 3 gigs of ram.
    Regards,
    Keith.
    When it closes on you again, could you please post the bottom of your log? You should find it here: C:\Users\[username]\AppData\Roaming\DAZ 3D\Studio4\log.txt if you are on a PC.
    Will do.
    Keith.
    Compiled E:/Temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Displacement.sdl...
    stdin: in function shader_Displacement
    stdin:438: WARNING: 'calculatenormal' function may have unexpected results since 'Pbp' in parameter number 1 is defined in a varying condition
    stdin:454: WARNING: 'calculatenormal' function may have unexpected results since 'Pbp' in parameter number 1 is defined in a varying condition
