Memorize and Restore Pose of selected body parts only
I seem to be blanking since I'm pretty sure I used to know how to do this. I have a 50 frame animation and need to copy the poses of only selected body parts from frame 0 to all other frames. How do I best do it?
Thanks
Redacted
Thanks for the suggestion but I checked out that product and decided that for a solution to what may be a one-time, or certainly rare, problem, it wasn't worth spending $20 for something that probably wouldn't have any other utility for me.
But I'll add this for others who might find this thread searching for answers to their problem:
I followed all the instructions for doing a partial pose reset, and was unable to get it to work. Whenever I unchecked the figure, then expanded the tree of bodyparts from the hip on down, I discovered that checking even a finger joint would re-check all those bodyparts back UP the chain, all the way to the hip again. Of course then when I would try to re-uncheck the hip (or upper chest, left collar, left shoulder, etc) all the parts below it again (including the ones I wanted checked) would get un-checked. There was no way to check only the body parts I wanted to include in the partial pose reset. Maybe it's a 4.20 bug or something - I don't know. So I did this: Select all the body parts I wanted to copy in Parameter view, then went to Edit > Figure > Memorize Selected Item(s) Pose, then at the frames I needed to copy them to: Edit > Figure > Restore Selected item(s) Pose. That did the trick.
Redacted
Ah, that explains it. Thanks for clarifying!
