4.20 rendering issue? Grovebrook park haunted
3D-GHDesign3D-GHDesign Posts: 711
edited February 2022 in Daz Studio Discussion
Something odd with 4.2 render.
The first image is the Grovebrook park haunted rendered in Daz Studio 4.15 out of the box. This is the scene included. Opened, selected camera and rendered. Just how it looks on promo (love it btw!)
But when I opened in Daz Studio 4.2 and did the same (opened the scene, select camera and render) it is dark.
All render settings are the same, because I just started DS and opened the scene and rendered. What happened?
Someone who has the same set should check in 4.2? MAybe it is only me?
Post edited by 3D-GHDesign on
    This must probably have to do  with the Ghostlight feature that has been changed in 4.20 (in Iray specifically, not done by DAZ Productions)
    Check this thread and its links to figure out what is going wrong (and what you can do)
    https://www.daz3d.com/forums/discussion/551331/4-20-update-interiors-now-super-dark-for-anyone-else
    Post edited by Paintbox on
  • Thank you!
  • That ghost light fix should work .. maybe .. if I can find ghost lights in the scene :D  I hope Predatron will update this for 4.2
    Ghost lights are invisible mesh lights. So geometry with a surface set to emit light, and then use the opacity to make it invisible. "Ghost light" is the result of that trick. In 4.20 Iray changed this to make a proper ghost light using a different technique.
  • Leo LeeLeo Lee Posts: 195
    After the 4.20 installation, Iray doesn't work for me at all. frown
    It stucks in Preparing the Scene... forever.
  • LeanaLeana Posts: 12,818
    Try updating your GPU drivers, that seems to fix the problem for most users I've seen posting about "Iray not rendering".
     where can I find a description of the new ghost lights ?
  • kyoreonakyoreona Posts: 213
    Is there any lighting scheme that can replace ghost lights in the new version?
