Nature - Lake and Forest [Commercial]
Andrey Pestryakov
Nature - Lake and Forest [http://www.daz3d.com/nature-lake-and-forest]
Addition for Nature - Lake [http://www.daz3d.com/nature-lake]
In this addition has been done a lot of work:
- The new ground textures
- The new textures of rocks
- Placed live trees
- Set new forest flowers
- Placed new bushes
- Reworked grass along the coast, and in the background. In the grass reduced the number of polygons, now it is rendered faster.
- Added belt of polygons around the scene with a dense texture of forest.
- Added the sphere of pure blue sky, for reflections in the water.
- Added optimized light source.
On the screenshot of the scene I processed only brightness. I used the "Atmospheric Effects Cameras for DAZ Studio" for the haze in the distance. Advantages of this addition is that you get the same render light and reflection in the water.
Love it, I own lots of sets from you :D
Thank you!
Please, you can see the promo video for addition Nature - Lake And Forest
http://www.youtube.com/watch?v=EYuhhxHAQiM
This looks fantastic. However when I looked at your video on youtube is said that this addition was for DazStudio. Are you going to make a Poser version as well since the original products were for both DazStudio and Poser?
Amazing as always.
..looks like a Carrara render. Very nicely done.
Yes, it's addition for DAZ Studio only. The DAZ Studio has the ability, that is not in Poser. This ability is to group objects and to disable them with a single click. It is necessary for this scene because if you load all objects in the scene, the camera simply will not normally rotate. Most of the items on time to work with the camera should be turned off. It should be turn on only before render.
Unfortunately Poser not able to group objects and disable them by one click.
http://my.smithmicro.com/tutorials/1023.html
In Poser is possible to set the parent object. But when I turn the visibility of the parent object, the other objects are not disabled.
I recorded a video: http://www.youtube.com/watch?v=jMAydpDcsR0
Maybe I'm doing something wrong?
I found something better:
http://forum.runtimedna.com/showthread.php?64932-GROUP-OBJECTS-IN-POSER-PRO-2012&p=625789&viewfull=1#post625789
and
http://forum.runtimedna.com/showthread.php?94768-Making-a-group-of-objects-invisible&p=860321#post860321
(sorry for the first link - it is hard to find grouping and Poser links that DON'T talk about grouping Polygons, but about creating a group of objects - the same word for both things does make it confusing)
Thank you Kerya, it works!!!!!
I'll try to do a scene for Poser, but it will work only in Poser Pro.
I purchased Nature - Lake and Forest. I downloaded and installed with DIM, but I am getting a lot of errors about missing textures and missing data files when I try to load it. I looked for some of the files, and they do not seem to be there. In the 3rd pic below there is no directory "Nature - Lake" as listed on the 2nd pic. There is a "Nature - Lake and Forest", but it does not contain the missing files.
I note that DIM says the installer is 3.4 GB. Is it possible that zip files this big do not work correctly?
Thank you for your purchase. This product is the addition for "Nature - Lake", it is written on the product page and in the promo video.
This is indeed the issue. I bought and installed the "Nature - Lake" and that fixed all the issues.
The funny think is, that I actually double checked the product page for "Nature - Lake and Forest" before posting this, and it did not list any Required Products. After reading your reply again, I check the product page and it still did not list any Required Products. Then by chance I used a different browser, where I was not logged into the DAZ Store, and it showed "Nature - Lake" as a required product. I double checked this and I'm sure that is what I was seeing. When logged into the DAZ store, it would not show me the required product.
Now that I have purchased "Nature - Lake", it shows as a required product for "Nature - Lake and Forest" when I am logged in.
Either there is some bug in the store that it will not show you required products you don't own after you purchase something, or it was just some hiccup in the store software that one day.
