Adding to Cart…
You don't have to load the character to attach it to Genesis 8 Female. The product places morphs and expressions (among other things) in a data folder where they are available to use the next time you load a G8 Female character. If the vendor left the character value set to 1.0, it will be the default value and will affect anyone who installs it on their system. Something similar to the "Baku" fix will clear up your problem. It will be as simple as changing a "1" to a "0", but which 1 is the trick.
To fix any ill-behaving morphs, do as follows;
1. Open DS and load "Genesis 8 Basic Female" (to an empty scene)
2. Right Click at Parameters Tab->Preferences->Choose "Show Hidden Properties" (part 3 zeroes only 'visible' dials)
3. Right Click at Parameters Tab->Zero->Zero Figure (Zeroes the value of all the 'visible' dials)
4. Right Click at Parameters Tab->Memorize->Memorize Figure (Sets the current value of all the dials as their default value)
5. Edit->Save As->Support Asset->Save Modified Assets (Writes the changed default value to the morph files that were changed)
When saving "Modified Assets" DS shows a dialog and asks for confirmation;
"The following file(s) will be permanently modified:" - "Accept/Cancel" - Choose "Accept"
@PerttiA: Thanks a lot!
Quick heads up, that wont work for ever case, encountered a couple of instances where the values were zero, it was badly done formula that was "pushing" values into the files, forcing DS into loading the morphs.
Basically the control asset didn't have any formula in it, and the bad formula was inside the head and body morph assets.
