Removing a character's eyebrows (Gayll)
I was trying to use the skin of the character "Gayll" and her eyebrows included in the package. But she already has default eyebrows (painted, I assume) and if I add the eyebrow attachment, those don't go away, so both eyebrows are superimposed. I don't see any way to remove the default ones. Is there something that I'm missing? Thanks in advance.
I often use https://www.daz3d.com/brow-remover-for-daz-studio
The product "Beautiful brows" by the talented PA chevybabe25 also has a brow remover that I often use.
@nemesis10 , @paintbox
Thanks, I noted both references, but shouldn't there be a way to remove the eyebrows in the product? It makes no sense to include special eyebrows if you can't use them because the default ones can't be removed...
On top of it, the default ones aren't even pretty, they're a thin greyish thing, making the skin essentially unusable.
You can't multiquote, here?
Ok, sorry, forget about it, my fault.
*I* had put two sets of eyebrows on the character. That of Gayll that I was using for the skin and that of the other character I was using for the shape.
