Anyone know why Victoria 8.1 has no normal or bump map for the lips? -solved
(edit) because it was not the hd version. hd version has normal map on the lips.
Post edited by vozolgant on
The HD version should use HD morphs, not normal maps.
Victoria 8.1 *DOES* have normal maps, both according to her file list in the readme (down at the bottom of the list), and accordng to what I'm seeing in her runtime/textures/Daz/Characters/Genesis8/Victoria8_1 directory (I have Victoria 8.1). They apply by default when you put the Character into a scene, so I'm not sure why you're not seeing them.
Victoria 8.1 HD has HD normal maps. Basically, much more enthusiastic and visible normals.
She does NOT have bump maps, because she's set up to work only with Iray, and Iray doesn't do as well with bump maps. She has no 3Delight settings, which would make better use of the bump maps.
