Bekka HD for Genesis 8.1 Female Not Rendering
I'm asking a lot of questions recently, I know
Anyway, as the title says, I'm having trouble with the Bekka HD for Genesis 8.1 Female. When I try to render, I just get a pure white skin (eyeless, I might add):
https://www.daz3d.com/bekka-hd-for-genesis-81-female
Is it maybe conflicting with something else I have in my library?
Any help is appreciated.
Hi Abraham. What version of Daz Studio are you using? Genesis 8.1 was introduced along with an updated PBR shader for the skin that requires Daz Studio 4.15 or higher. You can read about it on this page here. My guess would be that Bekka uses the new shaders and you might need to update to a newer version of Daz Studio to use it. I first tried using Victoria 8.1 in an older version and she rendered white just like your attached image. After updating, that problem went away.
Actually, that was the problem (I forgot I had 'downgraded' to a previous version of Daz in order to try to solve yet another problem with Dforce not working anymore [when it had with previous versions]).
Thanks for the help ^_^
