Settings for infinate render
DekeSlade
Simple question, what do I set my settings to for it to render infinitely till I cancel?
DekeSlade
I'm not sure if you can, but have you tried playing with the Preogressive Rendering settings?
Ive tinkered a lot and likely have. I know it can be done but dont remember how as some settings options have changed and others added.
MAX SAMPLES: infinate
Max Time: infinate
Render Quality: turn off, or turn on and set ratio to 100%
Now you can render infinate.
Hm, by infinity you mean 0 correct? As I remember that was part of it but now it is just bringing up the render window and stopping with nothing in it. Essentially looking transparent, which I have it set for a transparent background.
Try -1
4.16.0.3 and 4.16.1.43 are bumping -1 to 0. I would think this might be a bug, unless nVidia have changed the rules.
Just got back and gonna give it a whirl, thanks all! Will report back.
actually I mean a hugeeeee number.
-1 worked! Thanks @Richard
@Function A huge number wouldnt be infinate!!! ;P
Then it must be a bug. Nvidia didn't change the rules, the correct value for disabling Max Time / Max Sampes is -1. By the Iray Programmer's Manual from 2022-01-18 what is the current version.
