DS Zip Files
Can these be used to install content directly, instead of using DAZ Central, or the built in DS Studio installer?
  • LeanaLeana Posts: 12,846
    edited February 2022
    Yes, you can install content manually from zip files too.
    The zips made for DIM have the content files inside a top-level folder called "content". Take everything which is inside that folder and put it into your content library folder.
    Post edited by Leana on
  • jjoynerjjoyner Posts: 762
    Using advice that I read in a forum last year, I stopped logging into Daz Studio upon boot up so that the insidious updates from Daz Connect would not wreak havoc with my database or content library.  I never liked Daz Central when it was launched and have never used it to install content.
    I trust the Daz Install Manager (DIM), though, as it installs well to the locations that I have entered into the Advanced Settings in DIM.  On very rare occasion does something not install correctly via DIM.  A nice benefit of using DIM, though, is that it creates a list of installed files with a live hyperlink to each file's install location.  I use that at times to find or verify a file’s installation and/or location.
    Most of my manual installs are usually for products purchased at Renderosity although I recently discovered that I can use the Install from Zip Archive feature in Poser to install to any directory that I choose.  Some care needs to be take to ensure that unnecessary folders or files have been removed from the zipped folder first otherwise they will be installed.  For example, I installed a zipped folder for a Renderosity product recently where all of the desired content files were in folders that were inside of a Content folder; the Poser installation process created a new folder called Content and placed the underlying folders in it; not what I wanted.
    Once I manually install a product in Daz Studio, I create a Product for it using the Content Library.  That creates an item in Smart Content that has no product thumbnail and very limited metadata.  I use a product image that came with the product or which I downloaded from the product’s parent site (or which I create from a quick render in Daz Studio) to manually create and place a thumbnail in the Runtime/Support folder.
    382 x 478 - 52K
    792 x 551 - 119K
