• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Maya Discussion
Trying to match Maya OpenSubDiv to Daz Studio OpenSubDiv
mostlyhumanmostlyhuman Posts: 93
February 2022 in Maya Discussion
I have a genesis 8 character that was subdivded in Daz Studio to level 2, then I have a SubD 0 mesh that I am attempting to subdivide in Maya to level 2 so it can be used as a morph for the Daz SubD2 character but when I subdivide in Maya using OpenSubDiv (the same algorithm that Daz Studio uses)  the vertex orders do not match so the blendshape of course will not work correctly.  Has anyone been able to figure out if it is possible to subdivide in Maya in the same way Daz Studio subdivides?  I have a considerable amount of geometry to convert and I can batch convert in Maya whereas in Daz studio I have to do them one at a time so it would be a great time saver to figure out. Thank you for any help!
  • KainjyKainjy Posts: 888
    February 2022
    I don't think you can do it because the problem isn't the subdivision but the index of new vertices.
  • Richard HaseltineRichard Haseltine Posts: 108,531
    February 2022
    Why not export the divided mesh and morph that? Though don't forget that the rigging is designed to work with the base cage mesh, using a divided mesh (rather than having SubD applied to the final shape) is likely to present probelms, especially in the inner angles of bends. If you are wanting to load an HD morph on the base cage with live SubD, that isn't possible - only Daz pas have the tool, for use only on content for the Daz store.
  • mostlyhumanmostlyhuman Posts: 93
    February 2022
    Thanks guys, the issue is there are just so many files to process it takes forever doing it manually out of Daz Studio.  For instance last night I did all the Genesis 8 JCMs and it took an hour and a half laugh
  • stepharamburustepharamburu Posts: 33
    April 2022
    I have Maya and Blender and I can export any G8 character with subdivisions Level 2 and all body shapes perfectly inside Blender, but the same process doesn't work for Maya (First: with subdivision level 2 or 1, the mesh looks broken and Second: All morphs exported are visible but not useful when you animate the character -actually doesn't work-),. Does any know what I'd be doing wrong? Thanks!
  • AsariAsari Posts: 703
    April 2022 edited April 2022
    I need to try it myself again because I've changed my workflow between daz to maya, but if I remember correctly catclark inside Maya works. DAZ Studio needs to be catmull clark. If catclark doesn't work you can try to transfer vertice orders in Maya natively do the vertex order matches between your blendshape mesh and your mesh receiving the blendshape.
    However if you use the skinned mesh that comes out of daz to maya or Genesis 8 for Maya you get a smoothed mesh at base resolution. If you subdivide inside Maya and apply a higher subdivided mesh as a blendshape you will still lose some decent amount of detail. This also cannot be sufficiently fixed with displacement maps.
    It is possible to get a figure at any subdivision detail to Maya lisslessly but I don't know of any direct and easy way. All methods I know of require some serious tweaking and setup inside Maya.
    If you can get your figure into Blender you can try exporting via fbx and get it into Maya. The DAZ fbx exporter is wonky but maybe the Blender exporter works better?
    Post edited by Asari on April 2022
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
