Keeping Dress on her shoulder?
SandySims
Okay, this is simply Gen 8.1 female, the Kira Dress and the bench from Days of Cider. I'm trying to get her to sit on the bench and not have the shoulder of her dress slip down so far! I'm missing a setting somewhere obviously. Any help would be greatly appreciated.
You could try activating the Geometry editor tool, with the dress selected, and drag over a few polygons on the top edge to select them, add a dForce Weight Modifier Node (create menu), then switch to the Node weightmap brush tool, select or add dForce Simulation: Influence Weights map in Tool Settings, right-click>Weight Editing>Fill Selected and enter a value of 0. That should then anchor the edge of the shoulder (you could also try assigning a low non-zero value, to allow a bit of movement).
You could also try using setting a very slight contraction ratio on the dForce surface settings of the dress, or using a timeline animation to scale the dress slightly in the object properties pane after some frames. The later might work better, but either could cause it's own new issues as well.
