Daz Studio Pro 4.7 - Configuration problem
jeanguy_brunetjeanguy_brunet Posts: 2
Hello everyone
I downloaded Daz Studio Pro 4.7 and when I open my window is as :
and I want it to be like my second picture
your help would be greatly appreciated
thank you
  • PendraiaPendraia Posts: 3,627
    edited December 2014
    Hi,
    On the right hand side, just near the tab is a small rectangle with arrows. If you click on this it will open and close the tabs.
    Same deal on the timeline just click on the rectangle with the arrows and it should close.
    On the small bottom part of the left hand side tabs try clicking on the two dots.
    If you want to move any of the tabs then click on the tab and drag. To close them click on the x once you have dragged them. They can be reopened via Window\Panes
    Post edited by Pendraia on
  • Richard HaseltineRichard Haseltine Posts: 109,366
    Once you have it the way you want go to Window>Workspace>Save Layout As....
    Hi Richard, I missed that bit...really good advice though as that way you can just reload the layout.
  • jeanguy_brunetjeanguy_brunet Posts: 2
    Thank you for your answer
    But I misspoke Pendraia . In fact I would want my 3D scene is like in the picture # 2 and not as the image # 1. In other words, I would like that the whole is like the picture # 2.
    I hope to have a solution to my problem
    Thank you
    Thank you
    Try going to windows\workspace\select layout this will pop up a dialogue box. I think the layout similar to yours is Hollywood Blvd or the Full Service Beta. Not sure without actually applying them but the Hollywood Blvd looks the closest to yours.
    You may also need to go to Style\select\darkside after selecting the layout as I think that's what you have in your image.
  • larrygilmanlarrygilman Posts: 115
    There is a Preview Button in the lower left that will give a full screen with out making it permanent...at least till the next time you change it.
    I Thank You for your advice. I finally found the solution to my problem. I accidentally selected the Layout I accidentally selected the Layout inftead of Hollywood Blvd.
    Glad you managed to sort it out...: )
