Menu - Edit- Figure - Memorize Options - How to Use them?
I modified the Genesis / Genesis (2) avatars - During the Body modification and Posing I used Above Options Memorize Figure / Pose / Shape. After using the Memorize Opitons I further modified the Body shape and Pose. Now how to re-apply the Memorized figure pose or shape.
- Is it Possible to save the Memorized shape or pose.
Thanks in advance
Edit > Figure > Restore has all the options you are looking for.
If you want to save the poses and the shapes it's
File > Save As > Shaping Preset
File > Save As > Pose Preset
Thanks for your reply.
Once I utilized the Options Memorize Figure or Pose or Shape - How do I use or apply that Memorized Pose or Shape.
For example, After memorizing the Pose and Shape, further I modified figure Pose and shape - ( I do not want to use UNDO options or Save as Shaping or Posing Preset ) - Now, I want to retain the Shape but apply the Memorized Pose or vise-versa.
thanks
thanks
Restore will do exactly that. I know it sounds like it will return everything back to it's base state but it doesn't.
For that you would do Edit > Figure > Zero > Figure Pose or Figure Shape
it worked :-)
No Problem ;-)
